And then identify the cause of the occurrence of leaks, whether it is a break in the water pipes, corrosion in the pipes, or corrosion in the tanks, and the reason for this may be a hole in the pipes or tanks, all of these reasons may be a cause of water leaks after identifying the cause, whether apparent or Invisible plumbers do the work.
شركة كشف تسربات المياه بينبع
Our company can change the broken pipes or change the pipes that have a hole, and if the leakage is caused by the tanks, the tanks are dealt with through specialists in that through immediate maintenance, damage repair and cleaning of the tanks.
After that, waterproofing is done for the tanks so that the problem of water leaks does not recur again.
And not only that, but after fixing the main cause of water leaks, the team of our company, Water Leak Detection Company in Riyadh, repairs the severe damage resulting from these leaks, whether damage to paints or damage to walls and cracked floors. All of these damages can be repaired by our company at the lowest possible cost, and this is what distinguishes our company from others. of companies.
Steps to detect water leaks and solve the problem
Determine the problem and the type of leakage by experts, then start dealing with it while developing appropriate solutions to eliminate the leakage problem permanently. Make waterproofing of walls and roofs of real estate or in upper and lower tanks of any kind, and ensure that there are no leaks.
Dealing easily with water leaks by experts without causing the walls and floors to crack and without causing any harm to the house while preserving the floors and walls.
We have the latest devices and modern technologies that easily detect water leaks in Riyadh and in all cities of the Kingdom.
شركة كشف تسربات المياه بعسير
Periodic maintenance work through the Saudi Al-Safwa Company to ensure that none of the water pipes are corroded or rusted.
Using the latest devices, equipment and modern technologies that detect water leaks, whether they are apparent leaks or hidden leaks.
