Moisture under tiles
Humidity is one of the very annoying things that cause great harm to many families, especially home owners that are not exposed to good ventilation, and moisture comes from lack of ventilation and water getting inside the tiles.
شركة كشف تسربات المياه بالاحساء
The moisture of the tiles causes the tiles to crack and dissolve the adhesives for them, and also causes roughness and foot diseases, and because of the moisture under the tiles the sub-ceiling is affected and cracks that may lead to damage to the building as a whole if the treatment is not done and attention to that quickly and carefully.
Water must be handled tightly, because as it has great benefit, it has great harm, and take care to dry water continuously, give up tiles, and install ceramics because it is anti-moisture and safer.
Water leaks into the wall
Water seepage into the wall is one of the factors that cause moisture, which leads to cracking of walls and damage to paints, and the walls of the house are exposed to collapse if the humidity continues to increase and not move to fix it quickly.
The water works on rotting the walls and cracking the walls of the house, which may lead to erosion and corruption of the building. This is in addition to spoiling the aesthetic view of the view, which makes the residents feel embarrassed.
Moisture resulting from water leakage causes residents to suffer from asthma, common cold, rhinitis and roughness, and the elderly are the most vulnerable to disease due to humidity.
It causes water leakage, not being careful with the use of water and not making a strong insulation to protect the walls and protect them from being affected by water, and it may be caused by heavy rain fall and its entry between small holes in the walls or the use of poor types of pipes that quickly rust and corrode.
Work must be done to treat water leakage quickly, so as not to increase the risk of leakage and lead to the destruction of the wall and its erosion and endanger the lives of the residents, as the longer the treatment period increases, the cost to the customer and sometimes he needs him to demolish large parts of the place and rebuild it.
When noticing the cracks resulting from the leakage, one must go directly to a specialist to do a good examination, find the cause of the water leakage, and develop a plan to deal with it in a tight and effective manner, as experience is one of the basic conditions to start dealing with any specialist and have a good career with quality work and honesty.
Water leaking from bathroom ceiling
The bathroom is one of the places most exposed to water, and therefore the walls and ceiling may be affected by it quickly, which constitutes anxiety for residents and poses a threat to the safety of the building.
Water may leak from the bathroom ceiling due to a spoilage of one of the water connections, rust in the pipes, or the absence of a strong insulation that prevents water from leaking from the surface to the ceiling.
The water leakage causes many damages to the residents, spoiling the aesthetic appearance of the place, as it poses a danger to the entire building, and the leakage may extend to other areas of the house, which may lead to the lives of the residents and endanger them.
Sometimes the water leakage is not clear to the eye, and this needs to be searched for a distinguished company in order to discover and treat it as quickly as possible.
Leaking bathtub
Bathtub is one of the very important elements in bathrooms, bathtub is used in every home, hotel and villa, and indispensable for comfortably bathing.
Sometimes a water leak occurs through the bathtub, and this leakage is due to a technical defect in the installation, because it is possible that the installer may be a non-specialist
If the leakage of the bathtub is not caught, reinstalled properly and treated, if it is cracked or broken, the leak may reach the bathroom floor, and the water may store, the unpleasant odors come out, and musty the floor under the bathtub.
When installing plumbing tools or bathroom parts, care must be taken to deal with a professional and expert in plumbing and installation work to avoid any damage or leakage problem.
Water repellent material
Water leaks are the occurrence of a problem or break in one of the water connections, which leads to the exit of water and collects in the areas surrounding the breakage and this causes a state of panic and tension for the people due to the explosion of water, which may lead to damage to things in the house
Water leaks damage homes and may cause cracks in the building and breakage that may lead to falls if they were built on a strong foundation or the presence of a tight insulation
In recent times, a biotin substance was found to act as a strong waterproofing agent, prevent its leakage, and keep the walls and building intact without water reaching them and the occurrence of any cracks or cracks.
The material preserves the building from erosion, permanently isolates water from it, and extends its life span, which greatly calms the population and helps them.
شركة كشف تسربات المياه بالظهران
Reasons for smuggling pigeons
Due to the great exposure of the water to the water, it is most likely that the water leaks into the vicinity of the house or seeps into the walls
One of the reasons for smuggling the bathroom or leaking water is the presence of wide gaps between the floor tiles or a break in one of the pipes during tiling, which causes water leakage after a few periods
Water leakage causes great losses to the client and exposes him to paying large sums to address the problem, and being negligent in it causes more harm to the customer
Ceiling water leakage
Water leakage is one of the things that must be quickly noticed and repaired, so that it does not develop and is difficult to solve, and sometimes it does not exist, and puts the lives of residents in danger if it reaches a stage of collapse.
Water leakage from the roof of the house occurs as a result of the lack of a strong insulation that protects it, and as a result of the corruption of the water tanks on the top of the roof and the leakage of water from them, which leads to the appearance of cracks and the roof of drinking water.
Everyone, upon noticing cracks and paying attention to them, should immediately go to a specialist and an expert to make the necessary diagnosis and develop a good treatment plan.
The work is based on treating the cracks in many different ways, depending on the type and depth of the crack, and sometimes the problem ends by treating the causes that led to this crack.
One of the solutions that help in repairing the cracks is to make a ceiling insulator that insulates water and treats the things that caused water leaks or damaged connections that caused the ceilings to crack and spoil.
