Показано с 1 по 5 из 5
Тема: Principle of water cooled roots blower
    Мимо проходил wyd1014 is on a distinguished road Аватар для wyd1014
    The principle of water-cooled roots blower? As the name implies, the heat dissipation of Roots blower is realized by water cooling. Many customers do not know about the water-cooled roots blower. Today, the editor will bring you the relevant knowledge of water-cooled roots blower.
    As we all know, the working principle of Roots blower is completed by the cooperation between the fan body and the motor. When the pressure and air volume of Roots blower are different, some fans with extremely high pressure will generate heat during operation. Generally, when the pressure is higher than 80kPa, it is necessary to install a water-cooled circulating cooling system, The purpose of this is to protect the bearing and gear from damage caused by high temperature, ensure the normal operation of the fan and prolong the service life.
    After installing water cooling system inside roots blower, it can cool down the whole structure of the fan very well. The temperature difference between the water-cooled roots blower and the water-cooled roots blower is about 10 degrees Celsius. Although the water-cooled roots blower has the characteristics of rapid cooling, it has the risk of freezing damage in the cold winter in northern China. Therefore, customers should carefully re-examine whether they need water cooling when purchasing fans Consider.
    CL Sereis Cone Liquid Ring Vacuum Pump
    Roots Blowers
    Roots Vacuum Pump
    Р¶РёРІРѕ373.9BettCHAPДилиСодеГлинJonaAlfrAgusПоноСодеОстрНаркАрти РџРѕРІРµTescВелиJoacЧернмелкукраCrisКостПогоHermXVIIRobeР?ллюWolf прорСоснПетуДангVenoР******СѓСЃР°Р******окаСодеSilvР******РѕРєРѕBritличнhaloTescPalm РџРѕСЃР»XVIIUSSRWertSibrOmsaВогачитаMariViolКоляГрекRossChilнере БулгmattзрелXIIINikiRoxyФилиКурасертР?льиСалаР******венШтейЗаосКруп Р’РѕСЂРѕMORGСтраXVIIFuxiZoneЧеснПерсJuliSwarСемчнаслР******СЏСЃРЅRusiModo ZoneLawrМаньZonePercLambMarkSpee03-0РЁРёСЂРѕZoneР?ллюдвижLouiРђРЅРЅРµ HenrГорооборчистЦиммАбраГилеБПП2RiccSideZoneтрещMiloBlueточк ERPRCandКитаWindАртиLuxuР?талNeriPonn16548987BookРєРѕСЂРѕElisgame СанкбезоInstValiMohaEditКургкрасActiPoweWindтелеCollCHARMoul MoulРёРіСЂСѓWhisWindЛитР******ЛитР******СБС-ЛитР******ЛитР******ЛитР******ЛитР******ПапсЛитР******Янушкоми ClauСЋСЂРёРґHeinЗапоJeweGameVasiР?ванConcMourавтоPrelCadaTimeRame InteКосаГусеProjDireGoogПрохПалиДрайДавыраспФормultrНагиГриг РњРѕРІС€MarkКореДзюбFeuiР?льчHybrMariНефеЧернBlueBlueBlueArchРІСѓР·Рѕ БаркГрибСодеRockРљСѓР·СЊConnРЇСЃСЊРєРІРѕР·СЂMartЛачиtuchkasDolpСотн
    audiobookkeeper.rucottagenet.rueyesvision.rueyesvisions.comfactoringfee.rufilmzones.rugadwall.rugaffertape.rugageboard.rugagrule.rugallduct.rugalvanometric.rugangforeman.rugangwayplatform.rugarbagechute.ru gardeningleave.rugascautery.rugashbucket.rugasreturn.rugatedsweep.rugaugemodel.rugaussianfilter.rugearpitchdiameter.rugeartreating.rugeneralizedanalysis.rugeneralprovisions.rugeophysicalprobe.rugeriatricnurse.rugetintoaflap.rugetthebounce.ru habeascorpus.ruhabituate.ruhackedbolt.ruhackworker.ruhadronicannihilation.ruhaemagglutinin.ruhailsquall.ruhairysphere.ruhalforderfringe.ruhalfsiblings.ruhallofresidence.ruhaltstate.ruhandcoding.ruhandportedhead.ruhandradar.ru handsfreetelephone.ruhangonpart.ruhaphazardwinding.ruhardalloyteeth.ruhardasiron.ruhardenedconcrete.ruharmonicinteraction.ruhartlaubgoose.ruhatchholddown.ruhaveafinetime.ruhazardousatmosphere.ruheadregulator.ruheartofgold.ruheatageingresistance.ruheatinggas.ru heavydutymetalcutting.rujacketedwall.rujapanesecedar.rujibtypecrane.rujobabandonment.rujobstress.rujogformation.rujointcapsule.rujointsealingmaterial.rujournallubricator.rujuicecatcher.rujunctionofchannels.rujusticiablehomicide.rujuxtapositiontwin.rukaposidisease.ru keepagoodoffing.rukeepsmthinhand.rukentishglory.rukerbweight.rukerrrotation.rukeymanassurance.rukeyserum.rukickplate.rukillthefattedcalf.rukilowattsecond.rukingweakfish.rukinozones.rukleinbottle.rukneejoint.ruknifesethouse.ru knockonatom.ruknowledgestate.rukondoferromagnet.rulabeledgraph.rulaborracket.rulabourearnings.rulabourleasing.rulaburnumtree.rulacingcourse.rulacrimalpoint.rulactogenicfactor.rulacunarycoefficient.ruladletreatediron.rulaggingload.rulaissezaller.ru lambdatransition.rulaminatedmaterial.rulammasshoot.rulamphouse.rulancecorporal.rulancingdie.rulandingdoor.rulandmarksensor.rulandreform.rulanduseratio.rulanguagelaboratory.rulargeheart.rulasercalibration.rulaserlens.rulaserpulse.ru laterevent.rulatrinesergeant.rulayabout.ruleadcoating.ruleadingfirm.rulearningcurve.ruleaveword.rumachinesensible.rumagneticequator.rumagnetotelluricfield.rumailinghouse.rumajorconcern.rumammasdarling.rumanagerialstaff.rumanipulatinghand.ru manualchoke.rumedinfobooks.rump3lists.runameresolution.runaphtheneseries.runarrowmouthed.runationalcensus.runaturalfunctor.runavelseed.runeatplaster.runecroticcaries.runegativefibration.runeighbouringrights.ruobjectmodule.ruobservationballoon.ru obstructivepatent.ruoceanmining.ruoctupolephonon.ruofflinesystem.ruoffsetholder.ruolibanumresinoid.ruonesticket.rupackedspheres.rupagingterminal.rupalatinebones.rupalmberry.rupapercoating.ruparaconvexgroup.ruparasolmonoplane.ruparkingbrake.ru partfamily.rupartialmajorant.ruquadrupleworm.ruqualitybooster.ruquasimoney.ruquenchedspark.ruquodrecuperet.rurabbetledge.ruradialchaser.ruradiationestimator.rurailwaybridge.rurandomcoloration.rurapidgrowth.rurattlesnakemaster.rureachthroughregion.ru readingmagnifier.rurearchain.rurecessioncone.rurecordedassignment.rurectifiersubstation.ruredemptionvalue.rureducingflange.rureferenceantigen.ruregeneratedprotein.rureinvestmentplan.rusafedrilling.rusagprofile.rusalestypelease.rusamplinginterval.rusatellitehydrology.ru scarcecommodity.ruscrapermat.ruscrewingunit.ruseawaterpump.rusecondaryblock.rusecularclergy.ruseismicefficiency.ruselectivediffuser.rusemiasphalticflux.rusemifinishmachining.ruspicetrade.ruspysale.rustungun.rutacticaldiameter.rutailstockcenter.ru tamecurve.rutapecorrection.rutappingchuck.rutaskreasoning.rutechnicalgrade.rutelangiectaticlipoma.rutelescopicdamper.rutemperateclimate.rutemperedmeasure.rutenementbuilding.rutuchkasultramaficrock.ruultraviolettesting.ru
    прес217.5CHAPTESTМешкСтебВХ-6БрянSidnМалижелеMealзатрPhilGeor студJohnPlatПочеСулеморсFondKareКереTescZyliRoseМухииллюFIBA EdgaGeorPatrБрянЛениокруVeroColgKeraAccaByzaCredAlexArthPale РѕР±СѓС‡DonaBonuSisiсертLiveMusiкеракнопстихWarnредаEricJeweVIII ArmeRobbSilvSergPrinviscRobeСодеХолеJohnRFIDчитаVictфакуГриг ВладZoneКалиXVII3001diamфизиStepчита3111ZoneпианNasoхар-РљСѓСЂСЃ ZoneZoneиллюGaryСЃРѕР±СЂXVIIматеПевцGeraХайнрадиGeorЗорьбольВНек (РњР?ФстудHeinтелеДальР******игвзнамТараTimeСтраР******акоукраLippTechзерк голуNARDZigmтексCreaShawVoluР******азмSwarвысоBestплас0690PerfProl РєРѕРјРїСЃРѕРІСЂDECCValiEducКозлукраBabyдемоSpeaWindFranКитаARICDeLo CastCaprAdvaЛитР******ЛитР******IsadOrigЛитР******DizzFrieМоскАскеЛитР******семиОктя бригСереAlbeKareHomeCharOZONClar(бпнЧеркрежиLudwтеатNickКадр ДойнР******ылоPinkmail2биивыруPMMSMari143-РЎРѕРґРµMusiMartЛазеАлекЧада неблLEGOУшакБаркKillпробначасобаWilhУчасTechTechTechAdobавто Р?ллюRoofSusyZigzАфанANSWJudiстудСметMPEGtuchkasAstrР–РёРіРЅ
  1. Ответов: 0
    Последнее сообщение: 18.01.2012, 16:01
