How to clean wooden furniture
Wooden furniture is cleaned once a week as follows: Bring a non-toxic wood furniture cleaning spray.
Spray the mist spray on a cotton cloth, not directly on wooden furniture, and wipe it with it. Use a clean blush brush; For cleaning cracks and decorations in furniture. rub wooden furniture with a thin layer of wax paste; To restore its luster and isolate it from water.
How to clean wooden floors
Hardwood floors are cleaned with a wood floor cleaner spray as follows: Spray the floor every three feet with a wood floor cleaner. Run a microfiber mop along the hardwood floor and into all areas to pick up the dissolved dirt.
Put some baking soda on a damp cloth, and gently rub the footprints as you notice them until they disappear. Wipe it with a damp paper towel, then dry it.
Other ways to clean wooden surfaces
Other wooden surfaces such as wooden bowls and others can be cleaned using some harmless and safe household cleaners by following these steps: Bring lemon, olive oil, water, and a bowl.
Cut the lemon in half and squeeze it into a bowl, making sure to remove the pulp and seeds from the juice. Add a tablespoon of olive oil and another tablespoon of water. Stir the mixture well using the spoon, or put it in a bowl and close it and shake it well to ensure that the lemon juice and olive oil spread well in the water, and the lemon can be replaced with distilled white vinegar.
Add one tablespoon of vinegar for every three tablespoons of olive oil. Bring a cotton cloth, dip it in the solution, then squeeze it to become damp, not wet, and then wipe the wooden bowls with this cloth.
Note: It is recommended to test this mixture on a small area of ​​the surface to be cleaned before starting the full wiping process; To ensure that the mixture interacts well with the wooden surface.
translated from:
طرق تنظيف الكنب
طرق تنظيف السجاد المتسخ جدا
معلومات التنظيف
كلينينج هوم
