Use a degreaser
There are many types of degreasers that can be used to clean the kitchen walls and remove the accumulated grease, including: Creamy grease remover: used to get rid of stubborn fats, by applying it for at least 10 minutes on the stains so that the compounds it contains can break down the grease. And stains and remove them
You must follow the instructions included with the product about the correct cleaning method for this type of product. Powder grease remover: to be used in the following way: Wipe the wall with a cloth to get rid of easy stains. An amount of powdered degreaser is placed on the wall, to be mixed with a measure of hot water for better effectiveness in dissolving fat.
Scrub the wall with a sponge or soft cloth, and a soft-bristled brush can also be used to clean the corners of the walls, and it is worth noting that rubbing the wall must be avoided vigorously; Lest the outer layer of paint be removed. Rub the wall with a cloth dipped in water, then dry it with a dry cloth, then leave it to dry.
Use dishwashing liquid
Kitchen walls can be cleaned using dishwashing liquid in the following way: Grease stains are cleaned with paper towels. Loosen up residual stains with a washcloth soaked in warm water. Mix one to two drops of dishwashing liquid with one part of lukewarm water.
Dip a sponge with the resulting cleaning solution, then squeeze and rub it onto the wall with gentle circular motions. Wipe the wall with a cloth dipped in lukewarm water. Dry the wall with a towel.
Use vinegar
Vinegar can be used to clean the kitchen walls in one of the following ways: Concentrated white vinegar: a sponge is dipped in concentrated white vinegar, then the kitchen wall is wiped with it, and another sponge dipped in water is used to get rid of the grease and vinegar residue, then the walls are dried using paper towels. a
Vinegar with baking soda: Clean kitchen walls greased with tex or alkyd by mixing half a cup of vinegar, with a cup of pure ammonia, with a quarter cup of baking soda, with 3.78 liters of lukewarm water, then dip a sponge with a cleaning solution and wipe the kitchen walls with it
The walls are washed with water, and it is worth remembering to replace the sponge with old socks or nylon stockings when cleaning rough walls; So that the sponge does not tear and leave residues on the wall after cleaning it.
White vinegar and water: Mix a percentage of white vinegar with a percentage of hot water, then put the solution in a spray bottle, and spray the kitchen wall with it and leave it for a few minutes, then clean the wall with a cloth, and the process is repeated as needed, taking care to change the cloth if an area is cleaned Large walls.
The use of triple sodium phosphate
Kitchen walls can be cleaned with trisodium phosphate in the following way: Mix a quarter cup of trisodium phosphate for every 3.78 liters of lukewarm water, and if the walls are very dirty, mix half a cup of trisodium phosphate for every 3.78 liters of lukewarm water.
A sponge is dipped in the resulting solution and it is squeezed so that the solution does not drip onto other areas that are not intended for cleaning, causing a change in the color of the paint or causing damage to the wooden or metal surfaces in the kitchen.
Scrub the wall from the bottom to the top with a sponge. Leave the solution on the wall for two minutes to loosen the dirt. Wipe the wall with another sponge soaked in water.
Ironing
The kitchen wall covered with wallpaper can be cleaned and greasy stains removed from it by covering the wall with several paper towels, then the iron is set to a lower temperature, and then the paper towels are ironed to be able to absorb the grease stuck to the wall.
translated from:
طريقة تلميع البلاط
طريقة تنظيف الموكيت
طريقة تنظيف ستائر الرول
