Water leakage from pipes
- What is meant by water leakage is the exit of water from places that are not designated as a result of a break in the pipe, a hole, or as a result of a crack.
There are types of water leaks:
Visible leaks: those found in clear water connections; Therefore, it can be easily solved because it can be seen with the naked eye, such as: tank, taps, heater.
Hidden leaks: from their name they are hidden, not clear, because they are in the internal connections of water, they are inside the walls; So it is not easily detected.
There are some signs of water leaks, including the following: كشف تسربات المياه بالخرج
The high rate of the water bill than normal is one of the signs of a water leak, and it is often a hidden leak.
Water appears on the walls of the house, near the pipes, or on the floors of the kitchen and bathroom.
After turning off the water tap, a person may hear water sounds coming from the sewage pipes, this indicates the presence of leaks.
Cracks inside the water tank are a sign of water leaks.
- In the event of a water leakage in the house, it may take a time for a plumber to come and fix the problem after identifying it. Some steps can be taken:
We shut off all water sources and avoid opening them until the problem is resolved.
We open the taps until we empty the water stored in the pipes, and we must make sure that there is no water in the pipes.
With a piece of cloth we wipe the area around the infusion and dry it well.
We put a piece of cloth or a bowl under the leaked place; This is due to the possibility of water in the pipes.
Treating water leaks from pipes. Treating water leaks from pipes
1- Treatment with epoxy paste
This treatment is a temporary solution. Latex gloves should be put on to protect yourself from high temperatures.
- We first knead the paste well, and when it acquires a light gray color, we spread a thick layer of the paste around the area where the water leaked, and leave the paste for 10 minutes until it dries and sticks, then we open the water to make sure the problem is solved.
2- Treatment using piping clamps
The pipe clamp, known to some as a spur, is used for small leaks and is a quick and practical solution.
- We buy eaves that are suitable with the size of the pipe, and we also buy rubber gaskets. We wrap the rubber gasket over the leaked area above the hole of the pipe, then we install the sprays and fasten with a wrench. كشف تسربات المياه جنوب الرياض
3- Treatment with anti-fouling connections
- This treatment is considered one of the best treatments because it is a permanent solution to the problem of water leakage, but it requires a plumber or someone who has knowledge in cutting pipes and the appropriate dimensions of the pipe size.
تسرب الأنابيب
إذا كانت الأنابيب موجودة منذ فترة ، فقد يؤدي البلى والتلف إلى حدوث تسرب في خطوط الأنابيب. الأنابيب ، على سبيل المثال أنابيب نحاسية ، قد تصدأ ثم تنفجر بسبب ضغط الماء ، مما يسبب التسرب.
في بعض الأحيان ، قد يتم انسداد الأنابيب بالحطام ، مما يؤدي إلى ارتفاع ضغط المياه وبالتالي انفجار الأنابيب. تعتبر الأختام المكسورة وموصلات المياه السائبة ومفاصل الأنابيب التالفة أيضًا من المشكلات الشائعة لتسرب الأنابيب.
بعض الأنابيب غير مرئية ويتم إخفاؤها داخل الخزائن أو الجدران. يصعب حل هذه التسريبات ، وتحتاج إلى إقناع السباك بإصلاح ماسورة مسربة أو صنبور مسرب في أسرع وقت ممكن.
إصلاح تسرب الأنابيب
يمكن أن يكون إصلاح تسرب الأنابيب أمرًا صعبًا وصعبًا في التعامل معه إذا لم تكن لديك الخبرة. هذا صحيح بشكل خاص إذا كان الأنبوب غير مرئي للغاية أو مخفي داخل الخزائن أو الجدران. عند الاستعانة بسباك محترف لتسرب الأنابيب ، قد يوصي السباك بطرق الإصلاح التالية:
التبطين
ريبينج
إصلاح الأنابيب الخارجية عن طريق إضافة شيء دائم
استبدال جزء من الأنبوب
يمكن حل بعض مشاكل الأنابيب بنفسك. إذا كنت مهتمًا بـ DIY ، فيمكنك بسهولة استخدام Google لمقالات DIY.
تسريبات المرحاض
هناك ثلاثة أنواع شائعة من التسريبات - التسرب من الخزان ، والتسرب في الوعاء ، والتسرب من القاع.
تسرب من الخزان
يمكنك بسهولة إصلاح خزان المرحاض المتسرب عن طريق تغيير الحشوات المطاطية حول مسامير الخزان وغسالة البقع ، والتي يمكن أن تتدهور وتعطل بسبب الماء العسر والمعادن.
تسرب في الوعاء
عادة ما يكون التسرب في وعاء المرحاض بسبب وجود مكون خاطئ في خزان المرحاض. فيما يلي المصادر الشائعة للمشكلات:
يحتاج المرحاض Flapper إلى التنظيف أو المحاذاة أو الاستبدال
يقوم صمام تعبئة الماء (حيث يأتي الماء من الجدار) بتسريب الماء ببطء إلى الوعاء
لم تتم محاذاة أنبوب تعبئة الماء البلاستيكي الصغير بشكل صحيح
مياه المرحاض ترتفع بشكل كبير في الخزان والفيضانات
مع تقدم عمر نظام المرحاض ، تتدهور كفاءة مكونات النظام ويكون لديها فرصة أكبر للانهيار.
هذا ، يوصى عمومًا بشراء مجموعة استبدال كاملة لإصلاح المرحاض بدلاً من شراء الزعنفة الفردية ، وصمام تعبئة المياه ، والمسامير المقاومة للصدأ ، وأنبوب تعبئة المياه الصغير ، والعوامة الجديدة ، وقضيب التعويم المعدني الجديد ، ورافعة تدفق الخزان ، وسلسلة الزعنفة الجديدة ، و الأختام المطاطية بشكل منفصل.
عادةً ما تكون مجموعة أدوات إصلاح المرحاض غير مكلفة وستعمل على إصلاح جميع مشكلات تسريب المرحاض لفترة طويلة قادمة.
تسرب من القاع
يمكنك بسهولة تحديد التسرب من قاع المرحاض عندما ترى الماء يحيط بالقاع. سيكون الاحتياط الأول هو التوقف عن استخدام المرحاض في أسرع وقت ممكن.
عادة ما يكون الماء المتسرب من قاعدة المرحاض متسخًا مثل الماء الذي كان في الوعاء عند استخدام المرحاض. هناك عدة أسباب لحدوث مثل هذا التسرب:
شقوق في وعاء المرحاض
مشكلة في ختم الشمع
لم يتم إعداد المرحاض بحزم
قد يكون التسرب من مكان آخر
يمكن أن يكون التسرب من قاع مراحيض المرحاض خطيرًا حيث قد يؤدي الماء إلى إتلاف الأرضية السفلية والأرضية وربما السقوف الموجودة أسفل المرحاض.
