Home ways to expel ants
Cultivation of ant-repelling spices and spices: Some herbs and spices affect ants effectively, and contribute to expelling them from their nesting areas and presence due to their strong characteristics and aromas, which can be grown in the yard of the house, to repel ants and drive them away, such as: seedlings of mint, cinnamon, cayenne pepper, and cloves, And garlic, and others, and it can also be distributed around the house or in the places where it is, such as making a line of garlic cloves around the areas of its movement and its distances.
Wiping surfaces with bleach: bleach removes the smell of pheromones that swarms of ants follow and catch up with each other, and thus it disperses the ants and makes them lose the right path to catch up with each other, and it is used by wiping different surfaces, and places where ants walk or are suspected of being there, such as cabinets, the surface of the refrigerator, and tables and others.
Flour powder: Flour expels swarms of ants, as well as prevents them from crawling and moving around, and targeting food and foodstuffs in cupboards.
Double-sided adhesive tapes: These are tapes that contain adhesive materials on the upper and lower sides, and are used to protect cabinets and food preservation places from ants, by forming a barrier around the cabinets, sticking one of its sides to the ground and leaving the other side; So that swarms of ants stick to it when they approach and try to get into the cupboards.
Dishwashing liquid: The fragrant smells of dishwashing liquid attract swarms of ants and kill them, and therefore a container can be filled with a mixture of boiling water and dishwashing liquid, and placed around the ants’ nesting areas, or where they are located, so that they are attracted to it and fall into it, and permanently eliminate it.
Vinegar: Ants are alienated from the smell of vinegar and leave their places of presence, especially when they are saturated with its smell. It is used by mixing a part of vinegar with an equal part of water, placing it in a spray bottle, and spraying it on the places where ants are found on a regular basis. To get an effective result and get rid of it
TRANSLATED FROM:
شركة تنظيف بالخبر
مكافحة الصراصير بالعجينة السحرية بالرياض
مكافحة بق الفراش
