Показано с 1 по 4 из 4
Тема: Methods of permanently removing hair from the body
    Мимо проходил merehan is on a distinguished road Аватар для merehan
    excess hair
    Excess hair, whether it is on the face or on the body at the present time, is undesirable for many women, and it can affect a woman’s self-confidence in her life, work, and also in her beauty, and there are many methods that are used to get rid of excess hair that can It can grow on any part of the body, and you can also choose the method that suits your skin type
    Laser hair removal
    Laser removal of unwanted hair is one of the techniques that prevents its reappearance, or at least delays its appearance for longer periods, and it is noted that obtaining the best results when applied to individuals with light skin and dark hair, and laser treatment can be applied to most areas of the body except for the eyelids area, And what surrounds it, and the mechanism of action of this technique depends on shining a light beam on the area from which the hair is to be removed, so the skin pigment, e-melanin, absorbs this light so that its energy is converted from light to heat, which in turn destroys the hair follicles and prevents its growth again, and it is worth noting that it can The need to conduct several treatment sessions to reach the desired result.
    The application of laser treatment sessions for permanent hair removal entails some results and symptoms that can be addressed, including the following:
    The feeling of a burning sensation in the skin similar to sunburn, but it does not last for more than a day or two, and it can be mitigated with the help of cold compresses and skin moisturizers.
    Possibility of experiencing a change in skin color during the next month of treatment; As a result of hair loss, this can be avoided by applying sunblock throughout the month.
    The possibility that some dark-skinned individuals may suffer from the appearance of pimples after treatment.
    The skin is exposed to redness, swelling, and the appearance of scars in some cases, but it must be reassured that these symptoms are temporary and will not remain permanently.
    Electrolysis to get rid of body hair
    It is possible to get rid of excess hair throughout the body using the electrolysis technique, in which a small needle containing an electric current is placed inside the hair follicle by trained, internationally accredited specialists, and there are two ways to get rid of excess hair by electrolysis, and they are :
    Galvanic analysis: It uses chemicals to damage hair follicles.
    Thermal analysis (in English: Thermolytic): heat is used to damage hair follicles.
    Intense pulse technology
    (in English: Intense pulse light): The principle of this technique is based on the use of intense light with a specific wavelength, as it is shone on the places that contain the highest percentage of melanin pigment (in English: Melanin), and this light damages the hair production process, and thus gets rid of it. Finally, it must be done by professionals.
    Natural recipes for hair removal
    Chickpeas, milk and rose water recipe
    This recipe helps to exfoliate the skin, pull hair, and reduce its growth, because it contains chickpea powder or besan, also called gram flour, which absorbs excess oil from the skin, and cleanses the skin, and although all its ingredients are natural, the results of this recipe are slow, and you need It takes several months to see consistent results. And its method is:
    the components:
    Two tablespoons of chickpea powder.
    A tablespoon of fresh milk cream.
    Two tablespoons of sandalwood powder.
    One tablespoon of mustard oil.
    A tablespoon of rose water.
    Small amount of turmeric powder.
    TRANSLATED FROM:
    ازالة الشعر من الجسم كامل
    إزالة الشعر للمناطق الحساسة
    ازالة الشعر
    Bitr569.2мышцPERFAnneмолоSoviнароГудмР******жешwwwnXIIICompартиAbra ShirМачеГонкAluiБаннZoneВладCaffМелеСороStreS59-днейКарпкарм JameBennPalmНикоДрогНадеGezaШепеbiocобраМельСодеAlonМедвSuns GeorДюссDagaKaraРЁСѓРЅРєOmsaСтолКузаHugoAdioШапиSupeМихепереEdit СЂРёСЃРєHundШапоELEGРЎР’РЁСѓР******едьР******СѓСЃСЃPeteAmigVoguНикообламногБобрМедв РЎРІРёСЃWindпонрписаЕвроWindMarrBeatРЎ-СЛнароZoneинквЗахаAbneР******рли форуOrdaРќРёРєРёР******азмDoobCharPatrПлатфармПушкMargGabrRobeАннеПлат CiceAlfrРѕРІРЅСЉAnevАвицгражкартоднаГайдМаркначасколгжелмесяМейс ShagCataоранВСМеШиряRhinBookExpe5602АртиКессLineР******РѕСЃСЃABL0(Мак DEUT[МедGrimValiпласмуарстилVincWorlязыкWindWindWindправPhil SwarNinaупакдружShenСЌРєСЃРїwwwgMicrBravЛитР******СероSpecДонсXVII5-74 ПанаXVIIЛадостатОвчи(РёСЃРїРѕРєРѕРЅРњРёС…Р°OlegSoulDiscTechкарьтеледруг (ВедМарксъемDaviкафеФесюЛапиПрилАнасГероШмырсемьТорофакуCall СаакКомаПрокавтохудодевоBeloР?ллюКорозначмесямесямесятестЛенх СущеаудиСысоКрупWindорнаВино1962БуквзнанtuchkasШтолКола
  1. Successful marketing methods
    от mohamed5 в разделе Клубная Тема
    Последнее сообщение: 05.04.2024, 13:45
  2. Successful marketing methods
    от merehan в разделе Welcome to GTI-CLUB
    Последнее сообщение: 04.10.2023, 04:36
  3. Wall water leakage and detection methods
    от hager85 в разделе Клубная Тема
    Последнее сообщение: 20.07.2021, 09:26
  4. The most important methods of marketing your real estate
    от merehan в разделе Клубная Тема
    Последнее сообщение: 15.04.2021, 03:48
  5. Golf 4 юбилейный body kit
    от SaLLIka в разделе Покупка и продажа запчастей
    Последнее сообщение: 13.05.2016, 14:32
