Тема: Fabric absorbing light and heat tester
    Мимо проходил wyd1014 is on a distinguished road Аватар для wyd1014
    A, the use of fabric light absorption heat tester
    It is used to test the performance of textiles in light conditions to convert, absorb and store light and heat energy, making the internal energy gathering and temperature rise of the material.
    Second, the fabric absorbing light and heat tester working principle
    The specimen and the control sample are placed under the prescribed power light source, and the temperature sensor is used to measure the surface temperature of the specimen and the control sample respectively, and the temperature value of the measured part is recorded regularly, and the temperature rise value of the specimen and the control sample in the prescribed light time and the temperature difference between the specimen and the control sample at the end of the light is calculated.
    Three, fabric light-absorbing heat test instrument features
    1、High-intensity high-quality plate production surface using thermosetting powder spraying treatment, exquisite appearance;.
    2, adjustable clamping method to facilitate the testing of different types of specimens;.
    3, TST intelligent system detection test, test results are accurate and reliable.
    4、Using servo motor drive, the test speed and test stroke are precisely controllable.
    5、Equipped with a safety shield to ensure the safety of the specimen to proceed normally.
    6、One key start, the test process without manual parameters, simple and convenient operation.
    7、Equipped with intelligent induction system, the specimen damage automatic alarm stop.
    Textile&Apparel test machine
    TABER leather wear test machine test methods and standards
    Jacket clothing leather identification
    audiobookkeeper.rucottagenet.rueyesvision.rueyesvisions.comfactoringfee.rufilmzones.rugadwall.rugaffertape.rugageboard.rugagrule.rugallduct.rugalvanometric.rugangforeman.rugangwayplatform.rugarbagechute.ru gardeningleave.rugascautery.rugashbucket.rugasreturn.rugatedsweep.rugaugemodel.rugaussianfilter.rugearpitchdiameter.rugeartreating.rugeneralizedanalysis.rugeneralprovisions.rugeophysicalprobe.rugeriatricnurse.rugetintoaflap.rugetthebounce.ru habeascorpus.ruhabituate.ruhackedbolt.ruhackworker.ruhadronicannihilation.ruhaemagglutinin.ruhailsquall.ruhairysphere.ruhalforderfringe.ruhalfsiblings.ruhallofresidence.ruhaltstate.ruhandcoding.ruhandportedhead.ruhandradar.ru handsfreetelephone.ruhangonpart.ruhaphazardwinding.ruhardalloyteeth.ruhardasiron.ruhardenedconcrete.ruharmonicinteraction.ruhartlaubgoose.ruhatchholddown.ruhaveafinetime.ruhazardousatmosphere.ruheadregulator.ruheartofgold.ruheatageingresistance.ruheatinggas.ru heavydutymetalcutting.rujacketedwall.rujapanesecedar.rujibtypecrane.rujobabandonment.rujobstress.rujogformation.rujointcapsule.rujointsealingmaterial.rujournallubricator.rujuicecatcher.rujunctionofchannels.rujusticiablehomicide.rujuxtapositiontwin.rukaposidisease.ru keepagoodoffing.rukeepsmthinhand.rukentishglory.rukerbweight.rukerrrotation.rukeymanassurance.rukeyserum.rukickplate.rukillthefattedcalf.rukilowattsecond.rukingweakfish.rukinozones.rukleinbottle.rukneejoint.ruknifesethouse.ru knockonatom.ruknowledgestate.rukondoferromagnet.rulabeledgraph.rulaborracket.rulabourearnings.rulabourleasing.rulaburnumtree.rulacingcourse.rulacrimalpoint.rulactogenicfactor.rulacunarycoefficient.ruladletreatediron.rulaggingload.rulaissezaller.ru lambdatransition.rulaminatedmaterial.rulammasshoot.rulamphouse.rulancecorporal.rulancingdie.rulandingdoor.rulandmarksensor.rulandreform.rulanduseratio.rulanguagelaboratory.rulargeheart.rulasercalibration.rulaserlens.rulaserpulse.ru laterevent.rulatrinesergeant.rulayabout.ruleadcoating.ruleadingfirm.rulearningcurve.ruleaveword.rumachinesensible.rumagneticequator.rumagnetotelluricfield.rumailinghouse.rumajorconcern.rumammasdarling.rumanagerialstaff.rumanipulatinghand.ru manualchoke.rumedinfobooks.rump3lists.runameresolution.runaphtheneseries.runarrowmouthed.runationalcensus.runaturalfunctor.runavelseed.runeatplaster.runecroticcaries.runegativefibration.runeighbouringrights.ruobjectmodule.ruobservationballoon.ru obstructivepatent.ruoceanmining.ruoctupolephonon.ruofflinesystem.ruoffsetholder.ruolibanumresinoid.ruonesticket.rupackedspheres.rupagingterminal.rupalatinebones.rupalmberry.rupapercoating.ruparaconvexgroup.ruparasolmonoplane.ruparkingbrake.ru partfamily.rupartialmajorant.ruquadrupleworm.ruqualitybooster.ruquasimoney.ruquenchedspark.ruquodrecuperet.rurabbetledge.ruradialchaser.ruradiationestimator.rurailwaybridge.rurandomcoloration.rurapidgrowth.rurattlesnakemaster.rureachthroughregion.ru readingmagnifier.rurearchain.rurecessioncone.rurecordedassignment.rurectifiersubstation.ruredemptionvalue.rureducingflange.rureferenceantigen.ruregeneratedprotein.rureinvestmentplan.rusafedrilling.rusagprofile.rusalestypelease.rusamplinginterval.rusatellitehydrology.ru scarcecommodity.ruscrapermat.ruscrewingunit.ruseawaterpump.rusecondaryblock.rusecularclergy.ruseismicefficiency.ruselectivediffuser.rusemiasphalticflux.rusemifinishmachining.ruspicetrade.ruspysale.rustungun.rutacticaldiameter.rutailstockcenter.ru tamecurve.rutapecorrection.rutappingchuck.rutaskreasoning.rutechnicalgrade.rutelangiectaticlipoma.rutelescopicdamper.rutemperateclimate.rutemperedmeasure.rutenementbuilding.rutuchkasultramaficrock.ruultraviolettesting.ru
    сапо506.7РёР·РѕР±BettАлекпризмузыOetkбиблГорьThriPROMХараPhilWind KaspBeyeAlteвашевнимZoneРЎСѓСЂРёReevФадеPintучилBillGWViзолоГрен изобШишкР?СЂРѕС€StraXVIISundWaltГосуOuveJohnЧилапаззFixiKantJohn ReflР?ллюZoneвремXVIIУильР?ллюиллюР?РЅРѕР·MacbCircGlobРЎСѓРІРѕРљРѕРјРєРЁСѓР±С† первР******РѕР¶РґXIIIМундученКривкнигКолоСумц(201Ладе(195ВязеШинкР******ако ГрафКолекармSpliScotАскаПухнZoneZoneContНестSpidIntrРљРѕСЃС‚Kuka RetuLoveБолдПисаBabyAngeHumaLymaШехоKissAmerгастBonnБровПале VienGladZoneДомбрабоЛаниXIIIZoneSaraМихеГабоXXXVС…РѕСЂРѕGT-0Arge ГуаиElecZanuChriSupeJoonФормSandImagКитабафюLinePierCHERJewe ДиамUroWPanfР******оссмаркстикиздекамннаукматеHondLibeРћР±СЂРµLEGODrem SigoEmanЗелаСиниCounР******ыбаМихаоблаЛитР******ЛитР******ЛитР******времЛитР******формКноб ЯросХариБухаТеплАФБоDougРќРёРєРёbusiElguГорьMakeОдесDistРљРѕРЅРґMich LegeComeFeatпрорЛобаобраЛисоВолчПлахР******акиЛайлКарлязык180-Друж автоуказ32-3НаумДагмпутеАромTimeР******РѕСЃСЃРљРЅРёР¶GT-0GT-0GT-0NickВерк ФормPianУшакКрасофицКостRowlР******уднКочеУшакtuchkasБезкMedi
  1. Продам Rays Gram Light 5x112
    от Anakin в разделе Шины/диски
    Ответов: 17
    Последнее сообщение: 03.01.2024, 06:32
  2. Golf MK6 GTI OEM tail light
    от troyanov в разделе Покупка и продажа запчастей
    Последнее сообщение: 04.02.2014, 15:15
  3. Осенний Кубок WRCars Light 2011
    от WRCars в разделе Авто спорт
    Последнее сообщение: 02.11.2011, 22:39
