What are the signs of a water leak in the house?
There are some signs that may indicate the presence of leaks in the walls and floors of the house, including a noticeable and abnormal rise in the water bill, which indicates excessive water consumption, and some distinctive spots may appear on the walls and ceilings due to moisture or leaks, and some may notice the presence of Cracks in the ceiling and parts of buildings.
You can also identify the presence of leaks when you hear visible and unusual sounds in the pipes, as well as the presence of salts in the structure of the pipes from the outside, and the best means to identify leaks is to use a water leak detector to reach the location and cause of the leak directly.
The importance of water leak detectors
The importance of using a water leak detection device is due to a number of reasons, perhaps the most important of which is to accurately determine the location and cause of the leak without the need for cracking or drilling, which in turn leads to reducing expenses as well as effort in research and exploration, as well as using the device determines the place to be repaired without affecting the rest of the healthy connections .
Types of Underground Water Leak Detectors
Hidden leaks are considered one of the most dangerous and most important types of leaks, and their cause and location can be identified using one of the leak detection devices without demolition or cracking, including the electromagnetic wave water leak detection device, which sends waves inside the pipes showing the presence of leaks, the Aquaphone device, which is the most widely used and depends on Nitrogen gas pressure to determine the location of the leak through certain sounds and vibrations.
Also, at the Water Leak Detection Company, south of Riyadh, there is a pipe pressure gauge, a frequency oscillating device, a ground microphone, an audio leak detector, and a thermal camera device, each of which has its own advantages and special techniques through which the detection and identification of the cause of leaks is established.
aqua phone
The Aqua Phone is one of the best and most important devices used in searching and detecting sediments underground or behind walls. The technology of the water leak detection device depends on the pressure of pipes and connections with nitrogen gas, on the connections of different cold and hot water, and after gas pressure, the resulting sounds and vibrations are identified. Which the technician tracks to identify the location of the leak and treat it easily and without cracking.
When using nitrogen pressure, the volume of gas that is compressed inside the pipes must be taken into account so that it does not exceed the required percentage, which corresponds to the size of the pipes, which may lead to the explosion of the pipe, so when using this device, a specialized team must be used to avoid further damage and problems.
Electromagnetic wave detector
The work of the water leak detection device, when installed on the water pipes, depends on the issuance of a number of waves. Quick intervention to fix it before the problems get worse.
The results of these waves appear in the form of a warning, either light or sound, and this device gives its results with accuracy and can be used to detect leaks inside pipes and tubes with the same efficiency.
pressure measuring device
In this case, a water leak detector is used by installing it on water pipes that can be located inside walls and floors, and the device changes the existing kinetic energy as a result of the water flow into electrical energy, through which any change in the flow rate is monitored by reading the results of the indicator vibrations.
frequency oscillator
It is one of the distinguished devices that are used to detect leaks through vibrations, the device is small in size, it is the size of the palm of the hand, and when the vibrations are issued, this indicates the integrity of the connections and pipes and the absence of any leaks, while the interruption of these vibrations indicates that that area has damage or It scratches and causes water leakage, and therefore the necessary procedures for repair must be followed.
The vibrating water leak detection device is one of the best advanced devices that saves a lot of effort, time and money in discovering and repairing leaks without cracking or demolition, and the possibility of error when using this device is zero.
ground microphone
We can use the water leak detection device known as the ground microphone by listening to the sounds of water leaks and amplifying them electronically. The device filters and filters the noise so that it can isolate the sound and identify its source and locate it accurately.
The device works to detect water and liquid leaks in general, and the device is an easy-to-use device, and its price is reasonable compared to the rest of the devices and gives correct results in a large percentage.
acoustic leak detector
The acoustic water leak detection device is one of the specialized devices that are used to detect leaks at depths of up to 3 meters. It is available with a display and a headset that monitors the sounds of leaks with ease by displaying a graph of the frequencies density resulting from the presence of leaks.
The device is easy to use and can be easily traded among individuals who prefer to use it themselves, and can be dealt with without the need for extensive experience in identifying and detecting leaks
Translated from:
شركة كشف تسربات
شركة عزل اسطح بالدمام
