dry vacuum pump structure and characteristics
Vacuum pump is a device or device that uses mechanical, physical, chemical or physicochemical methods to exhaust the pump to get vacuum. Dry vacuum pump users in the application of vacuum pump knowledge need to master the following structure and characteristics, hope to help you.
The configuration of the vacuum pump body determines the overall structure of the pump. The entrance and exit are arranged in a horizontal and vertical structure for easy assembly and cable connection. However, the center of gravity of the pump is high, the stability of high-speed operation is poor, so this type is used for small pumps.
The horizontal pump is at the suction port and the exhaust port is below. The piping of the vacuum system is easy to install and connect, sometimes it can be discharged from the horizontal direction of the exhaust. That is to say, the exhaust directions are perpendicular to each other. At this time, in addition to the bypass valve at the other end of the exhaust pipe, the exhaust port can also be opened from left to right. The pump structure has low center of gravity and high speed stability. Generally speaking, large and medium pumps use this structure.
The two rotor shafts of the pump are installed perpendicular to the horizontal plane. The structure is easy to control the assembly clearance, the rotor is easy to install, and the pump area is small. However, the center of gravity of the pump is the height and the disassembly of the gear, and the lubrication mechanism is also very complex.
industrial vacuum pumps,vacuum furnaces
Rotary Vane Vacuum Pump
Dry Scroll Vacuum Pump
