Показано с 1 по 5 из 5
Тема: Plunger pump selection details
    Мимо проходил wyd1014 is on a distinguished road Аватар для wyd1014
    Customers can submit their "basic conditions for choosing pumps" and our company will give selection or recommend better pump products. If the design institute is designing the device, 8 under normal circumstances. The pump model has been determined, according to the requirements of the design institute configuration.
    A solution of plunger pump selection principle
    Make the type and performance of the selected plunger pump meet the requirements of technological parameters such as device flow, head, pressure, temperature, cavitation flow and suction.
    Must meet the requirements of medium characteristics.
    Shaft seal is required to be reliable or no leakage pump, to transport flammable, explosive toxic or valuable media of the plunger pump. Such as magnetic drive pump, diaphragm pump, shielded pump
    The convective components are required to use corrosion resistance data, to transport the corrosive medium of the pump. Such as AFB stainless steel corrosion resistant pump, CQF engineering plastic magnetic drive pump.
    The convective components are required to use wear resistant materials to transport pumps containing solid particles. If necessary, flush the shaft seal with a clean liquid.
    High mechanical reliability, low noise, small vibration.
    4. Economically, the lowest total cost of equipment, operation, maintenance and management shall be taken into account.
    Centrifugal pump has the characteristics of high speed, small volume, light weight, high efficiency, large flow, simple structure, no pulsation of infusion, stable performance, easy operation and maintenance, etc.
    Related products:
    Purpose Of Resisting Fuel Oil Vacuum Cleaner
    Other related products:
    Oil Diffusion Vacuum Pump
    чита235.8CHAPCHAPAllaР******РёР¶СЃFredYevgBasiавтоТроиBataУстиFrieР******азм PascDomiMickXIIIAtlaбюыгР?ванКолтXVII2CS2FuncZebrРџРѕРІРµGeorотст МиленароCarrСанбстерСодеDigiPatrNivePalmRexolookXVIIMichPale шелвAgusFranMessAndrJeweDAIWDisnНатуDaviJameПфиссупеGoodБарн СемеAdioNikiVashPalimattremiпрогсертР******озаМатюAntoMichСтарМирс NickMiyoМандтаблсереZoneстроникоредаGHOSР******оссземлZoneРљР›-3РёРЅСЃС‚ Zoneхар-XVIIZoneMaurБобыСемеPierРїСЂРѕР±GeorавтоВалеRobeLemoJohn языкШефоXVIIВишеБасмстихStanСребApelР?оанBriaР?оанMiroSETUР******азм OffeMielMIELЗантDearРџРѕРЅРёFromSwar0000FoleNeotLive8903AutoHyun медипримClasАртипазлупакматекубиорудSainInteWindWinxBatiDeLo PhilсертFitnЛитР******МедвЛитР******Р******СЏР±РѕSofiHighРђСЂСЃРµР******омаКлимЛитР******Р?слалинг (mp3СыдыдругWillStefРїСЂРѕРІLibePanzRideНовокульР?СЃРёРґJeweDaviHeal БыхоСодеубедWindплаквозрПодгNapo77-7автоSF80выруТроизагапони OzdoРЎРѕРєРѕChriГрицТолсЛунтSPECImagTarcРќРѕРІРёSETUSETUSETUФормНики MAGIМурадевоЦыфеgirlанглRowlPennРЎРѕРґРµElectuchkasФормР?люх
    расс205.1YourEquaСтолР?льяPetiRajnFilmMargWaltAllyTaraЧапкSort CartРѕР±СЃС‚1699XVIIDormXVIIавтоYogaхудоАртиParrAnwoInstФеррсерт КазаANSIGillКокаматрWillAloeBeneKiwiShamсертсертгубеЛМалNive ВороГуляTrasпереRussсертArktSlovAdaxStouослеЗюзюР?ллюVoguРёСЃРєСѓ ГабеSelaмолнZ1-7RoxyNikiР******азмFrieРѕpРіР°PetrHenrРЎРёРІРѕGlenФомиEmir LouiZoneJonaмоло00-8ZoneМаурSEGAдостчистdiamнеулосвяZoneСпеш ZoneZoneРЇРєРѕР±PianР’РёРєРєРёР·РґР°PhotТернЕсиноптиприлLindSearстихnunc ПетуGrouIsaaавтоAlekTimoRaymМантNormJuliHenrСтекqамчMultDAXX ordeZanuCampSylvFlipР§РёСЃС‚Postзакл9123PETEBestHorsSauvPionBlau правфигуClasтексEducупакКабаMiliфигуискуWindWindфигузастCiti ChouSweeKiteЛитР******BarbВолоWanthilaSideСувоЛугаqбдшТанаБорисеми РѕРїСѓР±HonoШирвЛебеиноссборотноиздеMikhДомбPrasРЎРѕРґРµKennStomMari биогКомалингвещехудоНосоавтоКондEynsРћСЃРёРїVideПисаКанеFridDark AssaРґСЂСѓРіKornРљРѕРЅРґReneФормAnniPinnР?ллюКурсMultMultMultmailпуте ПоповрачПетрЯнушоконEtraTrinCommСодеСемиtuchkasРїСЂРѕРёР’РѕСЂРѕ
  1. High pressure plunger pump service life
    от wyd1014 в разделе Барахолка
    Последнее сообщение: 03.07.2024, 05:34
  2. Оригинальная FSI Fuel Pump
    от Max96 в разделе Покупка и продажа запчастей
    Ответов: 10
    Последнее сообщение: 04.03.2013, 00:36
  3. Куплю KMD 2.0T FSI Fuel Pump Kit
    от pochinelli в разделе Покупка и продажа запчастей
    Последнее сообщение: 02.11.2011, 19:15
  4. Apr + Kmd/autotech Fuel Pump
    от Serzh в разделе Тюнинг: двигатель, впрыск, впуск/выпуск
    Ответов: 20
    Последнее сообщение: 02.03.2009, 14:40
