Customers can submit their "basic conditions for choosing pumps" and our company will give selection or recommend better pump products. If the design institute is designing the device, 8 under normal circumstances. The pump model has been determined, according to the requirements of the design institute configuration.
A solution of plunger pump selection principle
Make the type and performance of the selected plunger pump meet the requirements of technological parameters such as device flow, head, pressure, temperature, cavitation flow and suction.
Must meet the requirements of medium characteristics.
Shaft seal is required to be reliable or no leakage pump, to transport flammable, explosive toxic or valuable media of the plunger pump. Such as magnetic drive pump, diaphragm pump, shielded pump
The convective components are required to use corrosion resistance data, to transport the corrosive medium of the pump. Such as AFB stainless steel corrosion resistant pump, CQF engineering plastic magnetic drive pump.
The convective components are required to use wear resistant materials to transport pumps containing solid particles. If necessary, flush the shaft seal with a clean liquid.
High mechanical reliability, low noise, small vibration.
4. Economically, the lowest total cost of equipment, operation, maintenance and management shall be taken into account.
Centrifugal pump has the characteristics of high speed, small volume, light weight, high efficiency, large flow, simple structure, no pulsation of infusion, stable performance, easy operation and maintenance, etc.
Related products:
Purpose Of Resisting Fuel Oil Vacuum Cleaner
Other related products:
Oil Diffusion Vacuum Pump
