просто несколько ссылок для интересующихся.
очень интересно почитать :epti-work:
Part Numbers the OEM+ upgrade (k04-02x) (кликабельно)
Part - Part Desc
06A 253 033A-J 225 TT exhaust manifold
06A 145 704-M (or 06A 145 704-Q) K04-020 Turbo
06A 145 832-L Turbo outlet elbow
06A 121 08-1 Coolant Line
06A 121 497 G 2 00 Coolant line (not sure if last 3 digits belong)
06A 145 778-K Oil Line
06a 145 735J 3 00 Oil Line (not sure if last 3 digits belong)
102-090-05 Exhaust Manifold Nut
058-253-039-L Block to Exhaust Manifold Gasket
06A-253-039-H Exhaust Manifold to Turbo Gasket
06A-145-540-K Turbo Mounting Bolts (Inverse Torx)
06A-145-540-K Turbo to Downpipe Gasket)
06A-145-536-H Turbo bracket (under turbo mounts to block)
058-145-757-A Oil Return Line to Oil Pan Gasket
несколько вариантов K04 (кликабельно)
If one is interested in the k04-02x this is what is required:
K04-02X Turbo
Exhaust manifold
Exhaust up-pipe
An exhaust adapter made by Pro-Imports so you can use your K03 downpipe on this k04.
42 Draft Designs has released (Jan-22-2008) a full down pipe to be used on this turbo. 42DD k04 DP
Oil lines
either OEM TT's or custom ones made from Pro-Imports
Water/Coolant lines
(OEM or from PI)
Upper Intercooler Pipe
Only needed if you have a stock SMIC or upgraded SMIC
Lower Intercooler Pipe Reducer
Again only needed if you have a SMIC. I do believe a silicone reducer will work. Don't know the exact dimensions. Might have to guess and check
Silicone Turbo Inlet Hose
Samco type piece. Some cheap ones can be found on Ebay. Either OEM or one for the 225 TT
3" Mass Air flow sensor/ Housing
3" mass airflow housing from the TT or VR6.
Revo doesn't matter which sensor used. But Giac Requires the TT sensor
380cc injectors
Genesis work well or the OEM Audi TT's ran at a 4 bar on the FPR
4-bar Fuel Pressure Regulator
Or and adjustable one if you want
Hardware Kit
(includes all nuts, bolts, gaskets and other things to install this kit can be found at Pro-Imports)
Factory PCV Hoses with brass adapters
Pro Imports offers PCV relocation pieces
Software
GIAC, Revo, and Unitronics have specific software for the k04-02x. Pro-Imports is the only Revo dealer with this software/specific file
The official K04-02x VWVortex thread (кликабельно)
сижу, изучаю =)
