water detector
Water is one of the most important components of life for living organisms of all kinds, and there is a part of it in the ground, such as groundwater, so we need to dig wells; To search for such water, especially to irrigate crops, and some are working to recycle it for other purposes, as this search process needs specialized devices, to find the locations of water in those areas, so that we can find it as quickly as possible and with less effort, and this is what the technologies provide Agricultural engineering aims to find modern devices to be placed in the ground. These devices determine the locations of water, its depth in one meter, and determine it on the screen, and identify the strength of the water flow, its salinity and sweetness.
Ground and surface well water detectors
PR: It is a small and easy-to-use water detection device that contains all the systems for the search process. It works with soil resistance and sensing at the same time. It can find all types of water from fresh, salty and underground at a depth of 1000m in the ground. The device works On batteries it works for several hours extra.
Quattroforce: This device works on the geophysical system, easy to use and fast, where the device sends electric waves, through 4 iron rods that are implanted in the ground, and the device works on batteries that send waves of strength 110 volts, and the results appear on the LCD screen with values Digital, and audio indicators to show the signal coming from underground.
Tracker: It is considered one of the best devices for detecting water stored underground and at great depths. It is an electronic device that works in various environmental conditions and different types of soil. It can track water underground with high accuracy and ease, at a depth of 360 meters, and the device is not affected by site-specific disturbances. It operates at a power of 10MHz.
Water Detector Components
Color screen to display the facts on it (LCD).
5 volt AA alkaline battery.
Charger and charging indicator.
Sensor panels to track water availability.
Particle detector vibration frequency of 460MHz allowing you to get accurate results.
Sensor bars to track the signal.
A sensor for transmitting signals.
The main unit of the device is installed on the top of the device bag from the inside.
The electrodes or metal probes are four in number.
The cables connecting the signal are four, each of which is 20 meters long, covering an area of 1,000 square metres.
user's Guide.
شركة غسيل خزانات بالدمام
شركة عزل بالدمام
