<div class='quotetop'>Цитата(welty @ May 6 2008, 14:46) <{POST_SNAPBACK}></div><div class='quotemain'>с завода на AGU 3bar[/b][/quote]
+1 на гофли не ставят 4х барные регуляторы. даже на 180сильных AUQах на 3бара стоит.
<div class='quotetop'>Цитата(welty @ May 6 2008, 14:46) <{POST_SNAPBACK}></div><div class='quotemain'>21101
тогда у тебя побольше турбинка и более производительные форсунки[/b][/quote]
Да я уже запутался с этими турбинами и форсунками)
вот чего нарыл на фолькс.мск.ру
<div class='quotetop'>Цитата</div><div class='quotemain'>Dear Sir,
thank you for your interest in our products.
First of all, we don't produce any turbo that we call K03S. But I hope I can
answer your questions with the following explanations.
All the following turbos have the same installation dimensions and
thermodynamical performance. The differences are only in the actuator that
opens the turbine bypass valve:
K03-011 (5303 988 0011) 150 hp, 65 N actuator
K03-026 180 hp, 85 N actuator
K03-035 180 hp, 85 N actuator
K03-044 150 hp, 65 N actuator
K03-045 156 hp (Ibiza Cupra), 85 N actuator with 2 ports
K03-049 150 hp (Sharan/Alhambra), 65 N actuator
The 180 hp versions have an actuator with a higher opening force due to the
higher exhaust gas pressure (which is a consequence of the higher boost
pressure). Otherwise the valve would be pushed open by the exhaust gas
pressure.
The following turbos are a further development (since 2000) and have an
improved and slightly larger compressor while using the same turbine (still
with the same installation dimensions):
K03-052 180 hp, 85 N actuator
K03-053 150 hp, 85 N actuator
K03-058 150 hp/180 hp, 85 N actuator
Consequentially, putting a 180 hp turbo on a 150 hp engine will not bring
about any change in performance, but putting on a K03-052/053/058 instead of
the older versions will bring a slight improvement in engine efficiency.
Additionally, with re-mapping the ECU you can achieve about 215 hp without
danger of overspeeding the turbo. With the older turbos, 195 hp is the
limit.
With the K04 that's also commonly used (5304 950 0001) the power output
should not be more than 220 hp. That means, changing a K03-052/053/058
against a K04 does not make a lot of sense.
I hope that these details answer your questions. If you need more info, one
of our service distributors will be glad to help you. Their addresses are on
our website
Register or Login.
Mit freundlichen Gru?en/Best regards,
BorgWarner Turbo Systems GmbH
Sales IDS - Technical Support
Christian Seibert[/b][/quote]
самое на мой взгляд интересное подчеркнул
ЫЦ...
<div class='quotetop'>Цитата(1101 @ May 6 2008, 15:18) <{POST_SNAPBACK}></div><div class='quotemain'>Да я уже запутался с этими турбинами и форсунками)
самое на мой взгляд интересное подчеркнул[/b][/quote]
у тебя год выпуска какой?
сток
<div class='quotetop'>Цитата(3BEPb @ May 6 2008, 14:57) <{POST_SNAPBACK}></div><div class='quotemain'>+1 на гофли не ставят 4х барные регуляторы. даже на 180сильных AUQах на 3бара стоит.[/b][/quote]
на 180-ти сильных наличие 3bar регулятора компенсируется 314сс, а на AGU наличие всего лишь 205 сс компенсируется 4bar, и он при таких сцалках еще себя нормально чувствует по смеси и при 210 пони.
<div class='quotetop'>Цитата(welty @ May 6 2008, 15:19) <{POST_SNAPBACK}></div><div class='quotemain'>у тебя год выпуска какой?[/b][/quote]
по вину 16 декабря 1999 года, модельный ряд 2000
ЫЦ...
У меня сток форсунки и 3барный регулятор, при 210 силах оооочень сильно переливает!!!!!!
<div class='quotetop'>Цитата</div><div class='quotemain'>У меня сток форсунки и 3барный регулятор, при 210 силах оооочень сильно переливает!!!!!![/b][/quote]
А очень сильно - сколько? мультипликатив смотрел?
<div class='quotetop'>Цитата(nickart @ May 7 2008, 15:39) <{POST_SNAPBACK}></div><div class='quotemain'>смесь 11-11.5 до отсечки..[/b][/quote]
это что значит?
резве правильное сгорание, не при 14.7л на 1кг возуха?!
